Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › MAT_GLASS › Reply To: MAT_GLASS
Tonmoy
Hi Yoon,
The example file is in *.tgz extension, or in gunzip format. Please use winrar or similar software to extract the input deck residing inside it. If you're using terminal use can use the command tar -xvzf /path/to/yaris_windshield_mat_280_pse.tgz to extract those.
Thanks,
Tonmoy.
