Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Apply Force as a Function of Variable › Reply To: Apply Force as a Function of Variable
peteroznewman
Try applying a Bearing Load to a cylindrical face on the geometry. A Bearing Load creates a force on the nodes where the maximum force is at 0 degrees and zero force is at 90 degrees on either side and the distribution of force is sinusoidal.
There is a related constraint called a Compression only Support. See this discussion.
