Ansys Learning Forum Forums Discuss Simulation General Mechanical Need Help- Transient Thermal-Thermal Contact Reply To: Need Help- Transient Thermal-Thermal Contact
peteroznewman
Show the details for each of the three boundary conditions.
Is there air in contact with the lower sheet? Is the air enclosed or is there a room full of fresh air that can come in at the same low temperature to cool the lower sheet? If you have a room full of fresh air, then you should add a convection boundary condition.
Without a convection boundary condition, the faces of the sheet can't be cooled so the final temperature will be the same as the upper part.
Take the free courses on Convection Heat Transfer.
/courses/index.php/courses/heat-transfer/
/courses/index.php/courses/thermal-convection-in-heat-transfer/
/courses/wp-content/uploads/sites/2/2021/02/S1LT4C4L5-Handout-v1.pdf
