Ansys Learning Forum Forums Discuss Simulation Photonics ONA not giving results -Interconnect Reply To: ONA not giving results -Interconnect
Niki Papachristou
Hi Minu,
Thank you for reaching out to us. A common reason for what you are observing is the fact that The ONA will only record signals that are greater than the value of the ONA's "sensitivity" property, which is -100 dBm by default. Hence, if your signal is lower than this value then that might be the issue.
Can you try and investigate this and let me know if you managed to get your results or need more assistance?
Kind Regards,
Niki
