Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Non-linear calculation that fails, Deformation of a fence following an impact › Reply To: Non-linear calculation that fails, Deformation of a fence following an impact
Hi Armin, Â
Thank you again for your prompt feedback, I have applied your advice and we are still with a calculation around 48h.Â
We know it’s not a simple geometry but I think Ansys is able to work with more complicated models and I think we forgot something to complete our calculation.Â
Our fence is like that :Â Â
And we want to compare our model with real life tests we have realized. To explain quickly, we pulled on a beam (symbolized here by the cube) and measured the deformation as a function of the force applied. We want to validate a model who is giving close results to our tests.Â
And during our real test, it took us around 10s to remove the ties but if we make a model of 10s we have a time of resolution of 400h.Â
Do you think it’s possible to do it with Dynamics Explicit ? and how ? Is LS-DYNA a better solver for those long calculations (end time > 1s) but with highly nonlinear deformations ?
Thank you for your help.
Best regards
