Ansys Learning Forum Forums Discuss Simulation General Mechanical Force Convergence Issue in Solder Joint Reliability Simulations Reply To: Force Convergence Issue in Solder Joint Reliability Simulations
Harshil Goyal
I don't neeed frictional contact or thermal resistance in between so I guess the share topology is fine the way I am doing. I will use N-R Force Residual plots to see what bodies in my geometry is causing force convergence issue. I will reach out with those plots once I have the data. Thank you so much for your advise.Â
