Ansys Learning Forum Forums Discuss Simulation General Mechanical Compare compensated model from Additive Print to experimentally characterized co Reply To: Compare compensated model from Additive Print to experimentally characterized co
Akshay Maniyar
As per the description, it looks like you want to check the distortion between the actual printed part and the stl file which we can get from the final result of additive print. You can do it in SpaceClaim. You need to switch on the "Distortion compensation" feature.
Thanks,
Akshay Maniyar
