Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Meshing issues Nozzle geometry › Reply To: Meshing issues Nozzle geometry
March 28, 2024 at 5:34 pm
although we cannot do an online call for supporting this Forum, we can provide assistance and recommendations to the issues you are encountering.
What version of Meshing are you using?
Can you indicate what sections were successfully meshed, and which have failed.
You mentioned you suspect the Share topology to be causing the issue. What makes you think that? Are you able to mesh each section independently?
