Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Deactivation of ADPL command during simulation › Reply To: Deactivation of ADPL command during simulation
March 28, 2024 at 1:25 pm
Chandra Sekaran
Hi Lorenzo, You have to specifically delete the convection loads at the beginning of the second load step. So you need two command objects - the first one that applies the load in first load step. Then the second object should delete the load (may be with SFDEL or SFEDEL command) and this should have step selection mode set to 2.
