Ansys Learning Forum Forums Discuss Simulation Fluids “FLUENT failed to validate the connection” after a certain time Reply To: “FLUENT failed to validate the connection” after a certain time
Gary_S
Hi Mathieu
 Thank you very much for confirming.
umppc*****.dll (s) are part of an Endpoint Protection Program
It appears this Endpoint Protection Program causes isues with MPI (Parallel processing).
We have reports that it causes problem such as slowdowns or crashes in the Ansys and Fluent parallel solvers.
You may want to report this issue to your IT department.
Gary
