Ansys Learning Forum Forums Discuss Simulation Preprocessing Simulate a circular-shaped laminated glass Reply To: Simulate a circular-shaped laminated glass
peteroznewman
Open the geometry in SpaceClaim. Select the support ring edge and hit Ctrl-C, Ctrl-V to copy the edge and paste in a curve. Hide the solid bodies. In the Design tab, use the Pull tool to pull the the curve into a cylindrical surface. Pull the ends of the cylindrical surface until it is above and below the glass thickness. Unhide the solid bodies. Use the Split Body tool, select all three layers of solid body and use the cylindrical  surface to cut the bodies. Delete the cylindrical surface. On the Workbench tab, use the Share button and click the green check mark.
Those steps create shared topology of what should be sweepable solid bodies. The mesher will share nodes at the highlighted faces and edges so load will transfer across the layers without needing any contact. The bodies should be sweepable now and you should put a minimum of 2 quadratic elements through the thickness of each layer in the stack.
