Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Analysis of Robotic Finger › Reply To: Analysis of Robotic Finger
peteroznewman
The small scew orbiting a central screw is similar to a nut on a central screw. As the nut rotates, it travels along the axis of the central screw.
Link to a discussion that shows how to convert a Cylindrical Joint to a screw joint using some APDL code to represent a nut on a screw.
A joint is much preferred over using Contact to achive the desired motion.
