Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Problem with the definition of a path on a curved side › Reply To: Problem with the definition of a path on a curved side
March 27, 2024 at 7:13 pm
You have limited options to create paths. Basically you can use 2 points or an Edge. Using an edge should work. It is not clear why it did not work for your model. You can create a curved path using 2 points and a cylindrical coordinate system rather than a cartesian system. Can you create the path that you need using local cylindrical coordinate system?
