Ansys Learning Forum Forums Discuss Simulation LS Dyna LS-DYNA moment reaction Reply To: LS-DYNA moment reaction
Ram Gopisetti
Hi zhwzhwei,
Recently  we have given the option to use the binout tracker where you can check the moment causing from the remode displamcnet or the CNRB, currently it only gives out the forces but not the moments, so you have use the LSPP to read in the binout file then use the bndout sub-branch to post process the moments in subjective direction.
Cheers, Ram
