Ansys Learning Forum Forums Discuss Simulation General Mechanical Nodal acceleration from transient structural apdl Reply To: Nodal acceleration from transient structural apdl
avnish.pandey
Hi Lawal,
The commnads look fine. Try plotting the acceleration as well.
To determine the contact forces, you can select the contact elements, followed by selecting the associated nodes and then extracting the nodal forces using the commands given below:
/POST1
set,last
ESEL,s,ename,,CONTA171     !select contact elements either by ename or type
NSLE,s
ESLN,s
NFORCE
You can also explore GUI options to track contact behavior in APDL.
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v241/en/ans_ctec/Hlp_ctec_guiaids.html
