Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Dissolved Oxygen Simulation › Reply To: Dissolved Oxygen Simulation
Ghinna Nur Akram
Hi, Rob. I have tried setting the boundary conditions but there is no change. Then, I tried to remove the h2o (g) species in the mixture-template, and the divergence no longer occurred although there is a possibility that it will occur again. However, there was no increase in o2 concentration in the water. Apart from that, in my opinion the residual is not that good. What should I do?
