Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › Does not generate circles below 0.07 mm in diameter › Reply To: Does not generate circles below 0.07 mm in diameter
peteroznewman
Hi Daniel,
Once you choose a length scale, you must do all the modeling at that scale. The Standard scale allows you to draw objects up to 1000 meters about the origin, but means that you can't make very small features as you found out. The Small length scale allows you to draw much smaller features, but you will find it's not possible to create geometry very large or far from the origin.
