Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Winding excitation in 2D transient for Ansys Maxwell › Reply To: Winding excitation in 2D transient for Ansys Maxwell
GLUO
Delta/Wye connection is only defined in the external circuit instead of in excitation. If you would like to use a start connection with current source, you only need two sources due to KCL.
GL
