Ansys Learning Forum Forums Discuss Simulation Electronics Scattering and absorption efficiencies Reply To: Scattering and absorption efficiencies
Faezeh Tork Ladani
Hi Stephen,
To get the incident power, you just follow the same approach for fields calculator. Just in Edit Sources, use Incident Field in advance. Then whatever fields calculator expression is being calculated based on incident field.
