Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Static Structural / Non-linear analysis / Equilibrium iterations count › Reply To: Static Structural / Non-linear analysis / Equilibrium iterations count
jhicks
Thanks Peter ????
So (for example), if I see that my run is bisecting at substep 6, in my next run, I can "add" a Step at the end of substep 5 that will give substep 6 more substeps? Aka it will increment in a smaller time step than what the program automatically chooses.
Is that a control in workbench mechanical or does it need to be a command block?
