Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Named selections not being converted to labels – Ansys Fluent › Reply To: Named selections not being converted to labels – Ansys Fluent
March 26, 2024 at 2:04 pm
If you need those surfaces only for monitoring purposes, then you can take advantage of Imprint Surcaces 38.1. Using Surfaces (ansys.com) (see section 38.1.3 Imprint Surfaces).
You can have a single fluid cell zone. Create a new file that has only the vane surfaces and save it in .stl format. You will then be able to read this file in Fluent Solution and imprint them onto your fluid cell zone. You can then use those surfaces for monitoring or creating plots.
Let me know if this addresses your question or not.
