Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › Does not generate circles below 0.07 mm in diameter › Reply To: Does not generate circles below 0.07 mm in diameter
dl
Hi Peter, just a question I'm asking myself, it seems that by doing a drawing using the "Small" scale then I can't go back to the "Standard" scale, is there any way? It seems that if you start with µm you have to stay with that scale.
