Ansys Learning Forum Forums Discuss Simulation Electronics Eigen Mode Solver HFSS Reply To: Eigen Mode Solver HFSS
Praneeth
Hi Umer,
Thank you for reaching out to the Ansys learning forum.
Generally, the unit cell analysis is done using the Floquet port excitation along with coupled boundaries in HFSS. You can find an example design named "Split_Ring_Resonator" available under the "Open Examples" which demonstrates the implementation of the same.
Best regards,
Praneeth.Â
