Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › GPU A100 cannot be seen in ansys v241 mechanical and fluent › Reply To: GPU A100 cannot be seen in ansys v241 mechanical and fluent
Hiroshi Ito
Second, in the Fluent, the following warning message is detected on GUI.
Do you know how to enable to read "hardware-accelerated drivers" on the software??
Also, when I am using GPU for calculations, how to decide properly number of threads?
For example, can I set the 32 threads only for 4 GPUs? Or I should set 4 threads for 4 GPUs?
Thank you very much,,
