Ansys Learning Forum Forums Discuss Simulation LS Dyna Contact simulation not simulating deformation Reply To: Contact simulation not simulating deformation
Puneeth Bagaria
Since the velocity is very high, I would first suggest to check if the timestep of the simulation is reasonable. If so, you may try to use a different contact formulation (SOFT parameter). It controls the stiffness of the contact (and also changes a few more things)..
