Ansys Learning Forum Forums Discuss Simulation Fluids 2D conjugate heat transfer Reply To: 2D conjugate heat transfer
Mohammad Fikri
Thank you for your respons, So there is no other approach to do 2D except using the heatflux from the pins and 3D approach, i have done the pins approach, but because of the arrays are not dense enough, the flow boiling only happening near the pin, while in 3D models, the boiling occured more uniform across the plate.
