Ansys Learning Forum Forums Discuss Simulation Photonics Arbitrary sign for eigen mode Reply To: Arbitrary sign for eigen mode
Guilin Sun
I think the root cause of this is: some modes flips signs:
My tests show that in the following two cases the port modes are the same:
1: the ports do not shift;
2: using one waveguide
Why they change is hard say, as mentioned previously, we cannot control the didrection of mode direction.
I would like to check the actual device, and suggest that you manually check if the modes are the same.
