Ansys Learning Forum Forums Discuss Simulation Photonics Distribute Computing Reply To: Distribute Computing
Lito
@Sanket Bohora,
Have you tried running the simulation on the remote host/machine (qlinlabserver) while you are directly logged into the machine? Ensure that you can run the simulation from both machine while logged into them directly - as "localhost" in the Resources when logged into each machine.
Indicate the hostnames of the machines used in the resources. Make sure you have read/write access to the location/folder indicated by your MPI options/arguments. Try using "C:\" as your "APPDATA" - as shown in the image below.
