Ansys Learning Forum Forums Discuss Simulation LS Dyna Open/Import d3plots to Ansys workbench Reply To: Open/Import d3plots to Ansys workbench
Armin
Hi Soroosh,
Did you build your model within the workbench environment and then run it outside the workbench?
You can select the Solution branch, and then load the d3plot from the "Read Result Files" object in the Solution tab (see the screenshot below).
