Ansys Learning Forum Forums Discuss Simulation Fluids Energy conservation/balance in mixture multiphase Reply To: Energy conservation/balance in mixture multiphase
Amir
There is no Inlet/Outlet in my domain and it is a closed system. There is only an internal fan.
For mass, if I use reports->volume integrals-> then "Mass" or "mass-integral" for each phase is as follows: PH-1 is water-liquid and PH-2 is humid-air
Initial Mass:
Air Domain Mass (mix): 5.317779 KG
Air Domain Mass (ph-1): 0
Air Domain Mass (ph-2): 5.317779 KG
Air Domain Mass Intg (ph-2): 5.317779 KG
Liquid Water Mass Intg (ph-1): 0
Final:
Air Domain Mass (mix): 28.99604 KG
Air Domain Mass (ph-1): 23.66091 KG
Air Domain Mass (ph-2): 5.335128 KG
Air Domain Mass Intg (ph-2): 28.83929 KG
Liquid Water Mass Intg (ph-1): 156.7507 g
Some final values look too big.
