Ansys Learning Forum › Forums › Discuss Simulation › Fluids › limiting the maximum temperature of one component in fluent › Reply To: limiting the maximum temperature of one component in fluent
You may be able to do that with UDFs but what you then do with the excess heat is another problem. The FIX cell zone condition will set a zone temperature, but again that will have consequences for the remainder of the model. Assuming this is a real system think how that is controlled and once that's understood we can work out how to replicate the effect.
