Ansys Learning Forum Forums Discuss Simulation Fluids Dissolved Oxygen Simulation Reply To: Dissolved Oxygen Simulation
Ghinna Nur Akram
Hi, Rob. Thanks for your advice.
I wanted to change the properties of the water-oxygen material and this is what I did, I wanted to change the density to constant but there was no option to change it. How to?
Can this mixture also be used for other phases besides the gas phase, such as the liquid phase? Because I looked at the database, the only phase available was the gas phase.
Also I want to show the geometry I created where the inlet velocity is 0.0166 m/s.
