Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Error in meshing which says,”One or more entities failed to mesh.” › Reply To: Error in meshing which says,”One or more entities failed to mesh.”
Sampat Kumar
Hi
Thanks for your patience.
I hope you have tried to convert the facets body into a solid body (don't merge faces) before importing it into mechanical.
As I can see from the details of the mesh, the minimum edge length is zero under the sizing. there might be a chance that some elements in your model collapse to a point that causes issues.
I would suggest repairing the geometry and then trying to generate the mesh.
Best Regards,
Sampat
