Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Arbitrary sign for eigen mode › Reply To: Arbitrary sign for eigen mode
amitrotem2
I think you get small values because you moved the ports away from the blocks, or didn't flip their direction.
The original code show sign flips on S matrix values the has magnitude close to 1
The small shifts in Y are a sure way to see the issue of the sign flip. You can also see these with larger Y shifts.
