Ansys Learning Forum Forums Discuss Simulation Photonics Distribute Computing Reply To: Distribute Computing
Lito
@Sanket Bohora,
  1. The username and password you used to register with mpiexec are the ones you used when you logged in to the computer as prompted by Windows and should be the same on all machines that run the simulation.
  2. Try to temporarily disable the Windows firewall on the machines running the simulation. Or allow Intel MPI to access both machines.
