Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Ansys crashed while executing a coupled CFD-DEM simulation › Reply To: Ansys crashed while executing a coupled CFD-DEM simulation
March 22, 2024 at 3:50 pm
Here is another detailed excrept from the .trn file
If the solver was aborted, why does the .trn say that the solution converged?
Are you refering to the error-files?
If yes then there is nothing above that error messege in the .txt file
iter continuity u-phase-1 v-phase-1 w-phase-1 k epsilon time/iter
7976 9.5440e-04 2.4252e-07 1.9119e-07 1.6544e-07 3.6679e-04 5.5195e-04 0:05:51 40
7977 1.0127e-03 2.7070e-07 2.1197e-07 1.8304e-07 4.0245e-04 6.0717e-04 0:05:36 39
7978 2.1538e-03 2.6598e-07 2.0725e-07 1.7912e-07 4.0493e-04 6.1909e-04 0:05:23 38
7979 2.0234e-03 2.6087e-07 2.0331e-07 1.7582e-07 4.0219e-04 6.1531e-04 0:05:03 37
7980 1.8547e-03 2.5767e-07 2.0123e-07 1.7433e-07 3.9866e-04 6.0934e-04 0:04:54 36
7981 1.6949e-03 2.5547e-07 1.9996e-07 1.7351e-07 3.9487e-04 6.0266e-04 0:04:37 35
7982 1.5516e-03 2.5369e-07 1.9895e-07 1.7286e-07 3.9099e-04 5.9575e-04 0:04:23 34
7983 1.4228e-03 2.5207e-07 1.9795e-07 1.7214e-07 3.8707e-04 5.8874e-04 0:04:24 33
7984 1.3087e-03 2.5042e-07 1.9687e-07 1.7124e-07 3.8314e-04 5.8170e-04 0:04:29 32
7985 1.2056e-03 2.4868e-07 1.9566e-07 1.7013e-07 3.7923e-04 5.7476e-04 0:04:18 31
7986 1.1136e-03 2.4681e-07 1.9430e-07 1.6882e-07 3.7535e-04 5.6787e-04 0:04:08 30
7987 1.0320e-03 2.4479e-07 1.9281e-07 1.6732e-07 3.7151e-04 5.6109e-04 0:03:52 29
7988 9.5956e-04 2.4263e-07 1.9119e-07 1.6566e-07 3.6771e-04 5.5438e-04 0:03:44 28
! 7988 solution is converged
(update-animation-object “animation-2-pressure-plane”)
Creating animation sequence file: C:/Users/kiran/Desktop/ahmedbody 11/.//animation-2-pressure-plane.cxa
(update-animation-object “animation-velocity”)
Creating animation sequence file: C:/Users/kiran/Desktop/ahmedbody 11/.//animation-velocity.cxa
Flow time = 0.432304s, time step = 1318
1732 more time steps
Advancing DPM injections ….
Setting forces and torques on 4230 (of 4286) EDEM particles…
Done.
Getting particle data from EDEM…
Host sending injections to compute nodes.
Updating solution at time levels N and N-1.
done.
number tracked = 0
Tracking edem injections…
Particle timestep is the same as Flow timestep : 3.2800000000e-04[s]
Computing forces on EDEM particles… Done.
Updating EDEM solution …
Sending forces to EDEM…
Host receiving injections from compute nodes.
Done.
EDEM solution updated to time 4.326391e-01.
Done.
Getting EDEM solution data…
1 particle type sent.
Getting 4289 particles from EDEM solution.
4233 particles in injection ‘edem-injection’.
56 particles could not be located in Fluent.
Done.
Done.
7988 9.5956e-04 2.4263e-07 1.9119e-07 1.6566e-07 3.6771e-04 5.5438e-04 0:05:20 40
7989 1.0031e-03 2.7128e-07 2.1235e-07 1.8353e-07 4.0351e-04 6.0987e-04 0:05:20 39
7990 2.1150e-03 2.6667e-07 2.0776e-07 1.7965e-07 4.0626e-04 6.2338e-04 0:05:03 38
7991 1.9881e-03 2.6159e-07 2.0389e-07 1.7629e-07 4.0360e-04 6.1962e-04 0:04:47 37
7992 1.8252e-03 2.5829e-07 2.0181e-07 1.7469e-07 4.0004e-04 6.1346e-04 0:04:41 36
7993 1.6722e-03 2.5590e-07 2.0046e-07 1.7370e-07 3.9619e-04 6.0655e-04 0:04:28 35
7994 1.5343e-03 2.5400e-07 1.9939e-07 1.7288e-07 3.9225e-04 5.9941e-04 0:04:23 34
7995 1.4099e-03 2.5225e-07 1.9838e-07 1.7201e-07 3.8825e-04 5.9221e-04 0:04:17 33
7996 1.2980e-03 2.5049e-07 1.9730e-07 1.7098e-07 3.8425e-04 5.8508e-04 0:04:04 32
7997 1.1972e-03 2.4866e-07 1.9608e-07 1.6978e-07 3.8029e-04 5.7810e-04 0:04:05 31
7998 1.1079e-03 2.4671e-07 1.9474e-07 1.6839e-07 3.7637e-04 5.7119e-04 0:03:58 30
7999 1.0270e-03 2.4462e-07 1.9326e-07 1.6684e-07 3.7249e-04 5.6437e-04 0:03:50 29
8000 9.5556e-04 2.4241e-07 1.9166e-07 1.6514e-07 3.6868e-04 5.5771e-04 0:03:43 28
! 8000 solution is converged
Flow time = 0.432632s, time step = 1319
1731 more time steps
Setting forces and torques on 4233 (of 4289) EDEM particles…
Done.
done.
number tracked = 0
Done.
EDEM solution updated to time 4.329670e-01.
Done.
Getting 4292 particles from EDEM solution.
4236 particles in injection ‘edem-injection’.
Done.
Done.
8000 9.5556e-04 2.4241e-07 1.9166e-07 1.6514e-07 3.6868e-04 5.5771e-04 0:05:18 40
8001 1.0147e-03 2.7097e-07 2.1275e-07 1.8274e-07 4.0459e-04 6.1345e-04 0:05:18 39
8002 2.2788e-03 2.6629e-07 2.0805e-07 1.7882e-07 4.0713e-04 6.2513e-04 0:05:16 38
8003 2.1414e-03 2.6102e-07 2.0393e-07 1.7547e-07 4.0448e-04 6.2104e-04 0:05:13 37
8004 1.9595e-03 2.5775e-07 2.0174e-07 1.7404e-07 4.0095e-04 6.1451e-04 0:05:08 36
8005 1.7896e-03 2.5557e-07 2.0045e-07 1.7336e-07 3.9714e-04 6.0732e-04 0:05:17 35
8006 1.6351e-03 2.5388e-07 1.9951e-07 1.7287e-07 3.9326e-04 6.0007e-04 0:05:01 34
8007 1.4972e-03 2.5233e-07 1.9863e-07 1.7231e-07 3.8932e-04 5.9281e-04 0:04:59 33
8008 1.3736e-03 2.5077e-07 1.9768e-07 1.7159e-07 3.8538e-04 5.8558e-04 0:04:50 32
8009 1.2617e-03 2.4910e-07 1.9664e-07 1.7066e-07 3.8143e-04 5.7838e-04 0:04:47 31
8010 1.1620e-03 2.4729e-07 1.9547e-07 1.6952e-07 3.7751e-04 5.7131e-04 0:04:42 30
8011 1.0735e-03 2.4533e-07 1.9414e-07 1.6818e-07 3.7364e-04 5.6439e-04 0:04:24 29
8012 9.9597e-04 2.4322e-07 1.9266e-07 1.6666e-07 3.6982e-04 5.5767e-04 0:04:09 28
! 8012 solution is converged
(update-animation-object “animation-1-velocity-plane”)
Creating animation sequence file: C:/Users/kiran/Desktop/ahmedbody 11/.//animation-1-velocity-plane.cxa
(update-animation-object “animation-2-legs-plane-pressure”)
Creating animation sequence file: C:/Users/kiran/Desktop/ahmedbody 11/.//animation-2-legs-plane-pressure.cxa
(update-animation-object “animation-particle-tracks”)
DPM Iteration ….
Creating animation sequence file: C:/Users/kiran/Desktop/ahmedbody 11/.//animation-particle-tracks.cxa
