Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Material transition in dependence of temperature-field (melting process) › Reply To: Material transition in dependence of temperature-field (melting process)
Rahul Kumbhar
Hi Christoph,
Another way I can think of is using element 'Birth and death' option. You can deactivate the particular elements for the laodsteps when it is powder. Then activate the elements using this option for the laodsteps where these are solid material.
