Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Direction of principal stress › Reply To: Direction of principal stress
Rahul Kumbhar
Hi Anupama,
You can plot the vector principal stress plot and export the result (.xls file) which will give you the angles required to produce a coordinate system whose X, Y and Z-axis are the directions of maximum, middle and minimum principal quantities.
