Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Volume mesh is not conformal, hanging modes are found in the mesh. › Reply To: Volume mesh is not conformal, hanging modes are found in the mesh.
March 21, 2024 at 6:58 am
Kimmo Haanpää
Thank you very much for your help!
I am a new user, and in order to use the Maxwell3D simulation software for my work, I need to gain a sufficient understanding of result validity. This will help me build confidence that the simulation results are sufficiently close to the actual outcome. What is the prerequisite for using the software.
Below is the module I used and the solver type.
Below is (maybe) the number of mesh elements since the last pass, if it is the wrong number then please tell me where I can find the correct value.
