Ansys Learning Forum Forums Discuss Simulation Photonics Edge Coupler SiN waveguide to SMF fiber Strange Field Problem Reply To: Edge Coupler SiN waveguide to SMF fiber Strange Field Problem
George Nelson
Thanks to your pointing out that it is related to PML, I managed to fix the obvious problem in the videos. Here is the 100um taper result with the Xmax boundary set to stabilized PML setting:
https://youtu.be/m6Q1nIQtEU8
However, I noticed it still takes reaches the time limit set for the simulation instead of the early shutoff. The early shutoff does get triggered for 300um taper. I get >100% total transmission in for some wavelengths, too, so the mesh density or simulation accuracy must not be good enough. The simulations are already taking too long, so rather than increasing mesh density I will try to approach this problem some other way that is faster. I think I will start on the Fiber side rather than on the taper side first.
Final Results:
300um taper (Blue is total transmission, Red is transmission into fiber mode), looks ok:
100um taper, looks like accuracy is poor:
