Ansys Learning Forum Forums Discuss Simulation Preprocessing Workbench Import of Classic Model – Mesh Beam Issue Reply To: Workbench Import of Classic Model – Mesh Beam Issue
Gary_S
It does not appear this capability to import MESH section types was ever implemented in the External Model import.
Supported Source File Commands
The application imports the following source file data/commands as line body/beam cross sections:
CDB: The SECTION/REAL attribute defined with the element in the EBLOCK section.
BEAM, LINK and PIPE Types are supported.
The MESH Subtype is not supported.
