Ansys Learning Forum Forums Discuss Simulation Fluids Aeroacoustics – Negative Decibels Reply To: Aeroacoustics – Negative Decibels
Jack Spreadbury
Yes, an identical mesh was used, hence the confusion. I predicted a drop off in accuracy between LES and URANS but not as significant as this. Just wandering if there is any advice on how to fix this. The same reference pressure (default) was used for both.
