Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Adaptive mesh generation loop count › Reply To: Adaptive mesh generation loop count
The issue you’re encountering with the magnetostatic mesh generation could be caused by several factors:
1. Convergence: It’s possible that the simulation has already converged to a solution before completing all 10 cycles of adaptive mesh iteration. This could happen if the solution reaches a stable state earlier than anticipated.
2. Mesh Quality: The adaptive mesh iteration process may terminate early if the mesh quality meets predefined convergence criteria before reaching the maximum number of cycles. If the mesh is already sufficiently refined and provides accurate results, further iterations may not be necessary.
3. Simulation Parameters: Check if there are any parameters or settings related to plnkgame.com the adaptive mesh iteration process that could affect the termination criteria. Adjusting these parameters may allow the simulation to complete all 10 cycles as intended.
4. Resource Limitations: Insufficient computational resources such as memory or processing power could also cause the simulation to terminate prematurely. Make sure your system has enough resources to handle the simulation demands.
To address this problem, you can try the following steps:
- Review the convergence criteria and simulation settings to ensure they are appropriate for your analysis.
- Increase the number of adaptive mesh iteration cycles if necessary, or adjust other parameters related to mesh refinement.
- Verify that your system has adequate computational resources to handle the simulation requirements.
- If the issue persists, consider consulting the documentation or support resources provided by the software you’re using for further assistance.
