Ansys Learning Forum Forums Discuss Simulation Electronics Maxwell 3D ‘Find Conduction Path’ Error Reply To: Maxwell 3D ‘Find Conduction Path’ Error
Nick Husic
You can check the paths by right clicking excitations and going on conduction paths. I solved it by selecting all the conducting objects and changing the material to something else like diamond. I then changed it back to copper and it worked. This issue is likely due to importing the model from Altium, so if you didn't do that I'm not sure this will help.
