Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › 2023 R1 shell to shell bonded contact problem › Reply To: 2023 R1 shell to shell bonded contact problem
March 20, 2024 at 4:39 pm
Hi are you using face-to-face contact for frame1 to frame2 and so on? Have you tried turning the shell thickness effect on, and also set the contact and target shell face manually instead of using program controlled:
-Aniket
