Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Negative static gauge pressure in the domain while using ideal Gas law › Reply To: Negative static gauge pressure in the domain while using ideal Gas law
Can you zoom out? If you've set the outlet pressure as zero gauge, what is the operating density?
