Ansys Learning Forum › Forums › Discuss Simulation › Preprocessing › Workbench Import of Classic Model – Mesh Beam Issue › Reply To: Workbench Import of Classic Model – Mesh Beam Issue
ryan.aufdencamp
Hi Gary,
Thank you for your response -
I am able to see this option when dealing with line bodies native to SC or DM, but it seems the external model block is pre-integrating beams during the import process.
i.e. if I import a .cdb or .dat with defined mesh beam sections (SECTYPE,,BEAM,MESH), the cross-sections come in as ASEC (pre-integrated) sections. If I open these same .cdb or .dat files in classic, the mesh beam sections are preserved. Are you aware of any settings that preserves the mesh sections types during external model imports?
