Ansys Learning Forum Forums Discuss Simulation General Mechanical How to create a force displacement graph on APDL for an arch in static analysis? Reply To: How to create a force displacement graph on APDL for an arch in static analysis?
dlooman
If you used an arbitrary load step time of 1.0 we know the force will be 5000 N. times time.  Here is a way to make a force deflection plot in post26.  Use the /axlab command to create axes descriptions.
/post26
nsol,2,1574,uy  ! Displacement
xvar,2               ! Make Displacement the x axis
prod,3,1,,, ,,,5000   ! Variable 3 is time (variable 1 by default) times 5000
plvar,3             ! Plot force vs displacement
