Ansys Learning Forum › Forums › Discuss Simulation › Fluids › unresonable result when using polynomial fitting properties › Reply To: unresonable result when using polynomial fitting properties
The problem with the data you're taking from literature is it's 1.12345 x T^5 (for example), so 1.12345 x 350^5  if you do the sums how far off are you if you did the same with 1.234556 xT^5 ? Hence the use of piecewise linear tends to be safer. The error at a specific point will likely be far smaller than the rounding error multiplying a factor by 5,252,187,500,000 !
