mjmiddle
You have a scissors type structure which will certainly experience bending in some locations. The "bottom" offset is model dependent. View the mesh to see what side elements appear. Yes a surface coating is similar to shells with shared topology, but it should do it properly.
I see a "Stress tool" scoped to a surface coating gives zero results, so I submitted a defect report on that.
